help with mounts h22 hasport eg
I have an h22 in an eg.
The motor is already in but they did it ghetto style.
I recently bought hasport eg h22 mounts (second hand)
I have the instructions
http://www.hasport.com/tech/installs/egh1.PDF
However i dont see how im gonna get the tranny mount on.
can someone please show me better pics.
how does the tranny mount attach to the frame thanks
The tranny mount is kinda funky... It is a metal plate looking thing that sits on top of the trans and bolts down while it has a piece that goes under the passenger side frame rail.
There is another piece that bolts under the frame rail, where the front tranny mount used to bolt up.
The metal bracket that sits on top of the trans, slides into the little piece that bolts to the frame rail.
Hopefully that helps. goodl luck!
sorto of helps but not realy.
i have two pieces the mount and the tranny bracket .
i there a third piece, but it doesnt line up to any of the other two parts. i cannot figure it out for the life of me. its also not shown in the pics of the egh1 kit.
there instructions are bogus.
do i bolt the mount directly to the frame rail (underneath)
i need pix of one i have the egh1 someon please. i need to know if i got sold an incomplete kit.
Alright Ill try to explain it but im bad at explaining.
First take the black transmission bracket and mount it to the transmission. Then once you have the motor where you want it and lined up. You slide the Aluminum moon shaped mount on to the round part(shaft) of the transmission bracket. Then take your 2 hex bolts and bolt them in under the frame rail.
The rear tranny mount is also 2 pieces. Put the flat piece on the bottom and then the rear mount on top.
ok i completely understand now.
so there are holes down there to bolt it in.
ok new problem.
I noticed that the frame rail is tearing away from the body.
how hard is this to fix. and how much would it cost you think,.d
ok new problem.
Electron Eg
Nov 15, 2008 11:58 PM
