help everytime i rev i hear grinding
Old Feb 8, 2009 | 11:29 PM
bouncy23's Avatar
Default help everytime i rev i hear grinding
Everytime I rev I hear grinding sounds like its coming from my motor.
Old Feb 8, 2009 | 11:52 PM
Dilly's Avatar
Default Re: help everytime i rev i hear grinding
you sure its grinding? not rattling or ticking?
Old Feb 8, 2009 | 11:54 PM
Unseen Racer's Avatar
^^^^x2
also what kind of engine is it and do you have any mods?
Old Feb 9, 2009 | 12:19 AM
92civiceg9gsr's Avatar
You shouldnt put a grinder in your engine. Have you thought about the throw out bearing or input shaft bearing? At what times does this noise occur?
Old Feb 9, 2009 | 08:16 AM
uh it occurs when he reves his engine
Old Feb 9, 2009 | 09:08 AM
Former User's Avatar
Maybe a bad A/C idler pulley.
Remove the power steering, A/C, and then alternator belt in that order. If removing one of these belts eliminates the noise, then you have pinpointed the problem.
Old Feb 9, 2009 | 10:56 AM
andoxviii's Avatar
Check your engine oil before you drive it again.
Old Feb 11, 2009 | 03:41 AM
bouncy23's Avatar
I'm running a d16y7 stock. Its more of a grinding sound not a rattling
Old Feb 11, 2009 | 04:04 AM
jeremyrocksursox's Avatar
x2, check all your basic stuff first
Old Feb 16, 2009 | 02:55 AM
bouncy23's Avatar
I'm running 200 thousand miles on my motor any suggestions on how to maintain my car besides keeping up with my regular oil change?
Old Feb 16, 2009 | 08:23 AM
if it has that many miles, i would change the oil every 2,500 miles. and give it its tune up earlier than what it should be.
or just rev past 7,000rpm and buy a GSR!
Old Feb 16, 2009 | 08:24 AM
dividedas1's Avatar
i hate the new honda-tech.......
Old Feb 16, 2009 | 08:25 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Go get it diagnosed somewhere. You REALLY think that a bunch of people can pin point your issue over the internet with little to no details from you?
Go to a shop.
Old Feb 16, 2009 | 10:41 AM
lovelove's Avatar
yeah, you should get it diagnosed somewhere!! i agree with B_serious.
Old Feb 16, 2009 | 10:50 AM
c0d0r's Avatar
Put a long screwdriver to your transaxle housing and see if the grinding is coming from there..if it is, it's most likely your input shaft bearing.
Honda had an offical TSB for the problem back in the late 90's early 2000's I believe...my 1996 dx does the same thing.
Does it go away with the clutch pressed to the floor?
JasonYo
26
Oct 29, 2022 11:44 AM
OSIRIuS23
Jan 18, 2013 05:26 AM
lovelove
24
Feb 11, 2009 02:32 PM
FGalaxyR18
Honda Civic (2006 - 2015)
Feb 1, 2007 07:14 AM
ramz7887
May 12, 2003 03:58 PM
