HELP! code 20
Old Feb 8, 2009 | 10:09 PM
95gsrEG's Avatar
Icon3 HELP! code 20
i have a 92 teg with a b20b vtec it has a p72 ecu in it......and its throwin code 20(eld) and map sensor and i changed the map sensor and it still throwing it....i duno what to do....know of anything to try?
Old Feb 9, 2009 | 07:34 AM
95gsrEG's Avatar
Default Re: HELP! code 20
any1??
Old Feb 9, 2009 | 08:31 AM
HRTuning's Avatar
If you changed map sensors and it still throw it... Wiring.
Disable ELD.
Old Feb 9, 2009 | 09:49 AM
95gsrEG's Avatar
im guessing u have to chip the ecu to disable that correct? ive never had this happen b4..
Old Feb 9, 2009 | 10:08 AM
HRTuning's Avatar
Yup. I think your 92 doesn't have provisions for that. That code won't effect you much, but definitely fix the map sensor problem.
Old Feb 9, 2009 | 10:18 AM
95gsrEG's Avatar
its not hittin vtec at all..
Old Feb 9, 2009 | 10:29 AM
HRTuning's Avatar
Code 20 shouldn't cause that. Map sensor will, obviously.
Old Feb 9, 2009 | 12:11 PM
95gsrEG's Avatar
ive never seen an ecu like the one that is in it.....it has like two circuit boards in it...?
Old Feb 10, 2009 | 06:32 PM
Blown90hatcH's Avatar
IT does....JDM more than likely. Fix your MAP sensor issues and codes. The Code 20 will not effect Vtec.
Old Feb 12, 2009 | 08:46 AM
mouab18c1's Avatar
check your wires that connect to your ecu...
Old Feb 13, 2009 | 12:07 PM
95gsrEG's Avatar
it was the wiring.....but it bogs out everytime u slam a gear then the check engine light pops on the goes back out.....could the ecu just need chipped?
Old Feb 17, 2009 | 06:45 AM
mouab18c1's Avatar
stock p72 on a b20vtec? thats one of your problems right there....
FSUseminoleEM1
Feb 19, 2010 08:34 AM
Ndenbrock
Apr 11, 2006 05:51 PM
krz6jdm
Feb 21, 2006 01:36 AM
logistixz
Jun 20, 2002 01:06 PM
Frosty_spl
Feb 12, 2002 02:06 PM
