noob on eg
my Friend is getting a 94 manual civic coupe and wants to do a B16a/b or B18b/c swap. For the swap i have read you need the:
B series motor mounts
shift linkage
b series axles
and the wire harness for that engine
is there anything else im missing?
Mounts:
i assume the Bseries are comming out of a DC car so does that mean the mounts come out of a DC car as well?
and i also read that Hasport has these mounts as well is that true?
are all 3 mounts out of an integra or do i need a mount out of a Del sol?
Sorry about the noob questions, im a luder my self.
Shift linkages:
are the hydo better than the cable and where and for what trany do i get it for. I would like an example for a reference.
I know its an OBD1 shell so if i get an OBD2 engine and harness w ecu do i need a conversion harness say skunk2?
shift linkage
b series axles
Mounts:
Shift linkages:
my car has a b16 a swap, its an eg,
i have b series back bracket,
b series front trans bracket,
b series linkage,
singlecam wire harness,
and a hydraulic b16 trans. [eg is a hydraulic car, it requires a hydro tranny. unless you want to do the hydro to cable conversion, which is the dumbest thing possible]
if you have a vtec swap, get a vtec wire harness, if not, use the one you have.
lmk if you have anymore questions
b series linkage,
TitoSweetJr
10
Aug 11, 2011 02:27 PM
CRXB16B
Northern California (Sales)
Jun 12, 2005 08:14 AM
phantom_sol
Nov 19, 2003 11:28 AM
