Suspension & Brakes Theory, alignment, spring rates....
Please help!!!!
Old Feb 8, 2009 | 08:49 PM
sublimeh215's Avatar
Default Please help!!!!
i went to pepboys cus i need an alignment,.. And they said i cant do it without a camber kit..
My front wheels are wasting super quik!!
Is there any way of getting it aligned without a camber kit????
Please help!!
Old Feb 8, 2009 | 08:59 PM
Dang EG's Avatar
Default Re: Please help!!!!
As all the other senior and educated HT'ers would say is that it is true that they can not fix your camber unless you have some type of camber kit installed on your vehicle.
Yet, they would say to get it aligned for your toe and no matter what negative camber you have, fixing the toe will greatly reduce the tire wear you will have in the future.
Old Feb 8, 2009 | 09:05 PM
sorry im new with this camber thing.
yea thats true tho.
where can i take my car to get the toe aligned??
Old Feb 8, 2009 | 10:40 PM
hybrid90's Avatar
yea thats true tho.
Take it back to Pepboys and just tell them you want your toe dialed in to zero, that should save your tires. Most shops will tell you to get a camber kit when they see a lowered car pulling in cuz they'll automatically think you'll want your camber at zero... but I know many that ride on major camber with zero toe that never has any issues with tire wear...
Old Feb 9, 2009 | 06:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If they insist that they "can't" align the car without a camber kit, then they are idiots, and you should take your car somewhere else. Negative camber is NOT the cause for your uneven tire wear, it's the toe-out on the tires due to lowering. Any competent shop can and should set your toe to factory specs, which will pretty much eliminate uneven tire wear.
However, depending on the shop and their equipment and how low your car is, there could be problems getting the car on the rack, or getting the laser equipment to see across under the car. I used to always have to remove my front bumper to have my car aligned, and that was just when I was on H&R Sport springs.
Old Feb 10, 2009 | 07:34 PM
cool guys thanks alot =]
i will let u guys kno wats up as soon as i take it tomorrow morning!
2n-chilli
Suspension & Brakes
Apr 14, 2011 06:24 PM
EJ6_Sedan
26
Mar 5, 2008 06:21 PM
crx1009
Apr 5, 2006 09:57 AM
Trumpster
Suspension & Brakes
Feb 2, 2005 08:14 PM
toooslow
May 7, 2003 12:38 PM
