Any of you AEM EMS guys running FJO Sensors on your drag set-up?
Hey guy, I been looking at the FJO Gauge sensors. Has anyone use them on the AEM EMS? Their about $55 ( no pigtail I believe, but Horsepower freaks has the connector for $11) a sensor compared to AEM's $150 a sensor. They seem to be better quality too. Looking to use them to set up the safety features of cutting engine power if a oil or fuel pump fails.
http://performance.yoparts.com/fjo/f.../i-110997.aspx
If anyone has done it:
1) How did you set it up on the AEM, what # EMS used, etc
2) Where did you buy the sensors etc
3) what pin outs did you use
Thanks
Thanks
I was using the FJO sensor with my AEM since 2000. Two years ago the sensor started to go bad and it was only a few dollars more for me to buy a complete AEM wideband unit vs buying a new NTK sensor for the FJO. So I purchased a new AEM wideband.
I was using the FJO on a 1000 box and a 1040 box. Just got into the software and select the FJO sensor and then 'sync' the wideband readout with your aem and guage.
I never bought a new sensor b/c it was so expensive. The new FJO boxes can use the NTK sensors or the cheaper bosch sensors.
I do not know the pin out off the top of my head but if you look in your manual it is clearly stated.
Hope that helps
Hope that helps
Guest
Posts: n/a
Maybe not the PN exactly and such but we ordered a Motec 5 bar and it was the same look/body except the Motec had female NPT on it I think? As opposed to the male NPT on the AEM unit.
Hope that helps
Hope that helps
Hey Tony, have you had any customers running FJO pressure sensors with AEM???
Thanks guys
