GSR oil pan
Old Feb 8, 2009 | 08:15 PM
shortstopNE's Avatar
Default GSR oil pan
I have a turbo gsr swap in my 99 coupe and the gsr is out of a 2000 integra. I wanna redo my oil return and get a new pan but I was told that 98+ pans are deeper but i have seen that the 94-01's are all the same. Reason i dont retap mine now is because i want to go with a stainless return line and the fittings are different. Any knowledge is appreciated.
Old Feb 8, 2009 | 10:44 PM
teamworxek9's Avatar
Default Re: GSR oil pan
All gsr pans are deeper to accommodate the oil pickup.
Old Feb 9, 2009 | 05:27 AM
Vindicator9000's Avatar
318 Curves, 11 miles
just out of curiosity... I'm assuming that means I can't use a b18b oil pan on a gsr, right? Just wondering because I have a hole in mine and I'm trying to replace it without giving $180 to Honda... I can junkyard a b18b pan for next to nothing.
Old Feb 9, 2009 | 08:31 AM
Mashimaro's Avatar
the LS oil pan will not work with the GSR. You'll have to find yourself a GSR or an ITR oilpan. i'm not too sure about the B16 oilpan though...
Old Feb 9, 2009 | 09:27 AM
The ls pan wont work unless you get a shorter ls oil pick up, whch is cheaper than getting a oil pan.
Old Feb 9, 2009 | 10:14 AM
thanks guys... now I'm thinking I'm just going to find someone to weld it. Seems like gsr pans are expensive and hard to find around here.
Old Feb 10, 2009 | 03:14 PM
b16 dont work either, gsr all the way (tried first hand lol)
Old Feb 10, 2009 | 08:59 PM
hndacord02's Avatar
i have a gsr pan if your interested... just collecting dust in my basement...
Old Feb 10, 2009 | 09:06 PM
iwanttokillgod's Avatar
only gsr or itr no other pan will fit because the gsr or itr oil windage tray is bigger baffle
Old Feb 10, 2009 | 09:20 PM
I AM WEASEL's Avatar
The B16 pan is the same as the LS so no it will not work either.
Daniel-sanB1
Jun 25, 2007 03:18 PM
LsVtechybridracer
Oct 6, 2002 09:17 PM
DIRep972
Sep 22, 2001 11:06 AM
