EG clock problem
EG clock problem
So the clock in my eg sedan only works when i hit the button to brighten it up (button all the way to the right) what could be the problem , ive tried dif. clocks by the way.
Re: EG clock problem
Pop your hood, then open up the fuse box by the battery. Check the fuse labeled 'back up'.
I had the same problem, but in addition to the clock problem my stereo wouldn't work. Both the clock and stereo started working after I replaced the 'back up' fuse.
Do you have a stereo in you car, and if so, is it working?
white 95 is right the clock will light up by pressing but not keep time if your backup fues is popped. also stereo will not keep presets. Alot of the time monkeying with the stereo will pop this fuse.
/I had the same problem, but in addition to the clock problem my stereo wouldn't work. Both the clock and stereo started working after I replaced the 'back up' fuse.
