Diy Cruise Control Removal on 00 si
Old Feb 8, 2009 | 07:29 PM
cinci00si's Avatar
Default Diy Cruise Control Removal on 00 si
Anyone have anything on it? Hard? Easy? I cant search since its down and all.
Old Feb 8, 2009 | 07:48 PM
cinci00si's Avatar
Default Re: Diy Cruise Control Removal on 00 si
bump?
Old Feb 8, 2009 | 07:58 PM
2k_Si's Avatar
Its easy bro. I did mines in like 30 min. Just follow the cable to your pedal. Theres 2 of them. One for your throtle cable. The other one your cc. Just unhook it from your pedal and un-do the grommet in the firewall. The rest is just taking bolts off.
Old Feb 8, 2009 | 08:21 PM
cinci00si's Avatar
ahh cool so no dealing with any electical other then the housing of the buttons and what not?
Old Feb 8, 2009 | 08:29 PM
2k_Si's Avatar
As far as under the hood connections. No. There is a cruise cotrol module under your dash. I didnt remove that cause that didn't bother me. Also if in the future i wanted cc. It be less of a hassle to hook back up. I left my steering wheel controls alone. im a noob and i thought it was easy lol. give it a try
Old Feb 8, 2009 | 08:55 PM
kaluwa3's Avatar
Like he said remove the cruise control cable from your throttle. Unbolt the cruise control unit from the engine bay (I believe it's 3 bolts, I forget what size). Follow the plastic vaccum line back to the top right corner of your engine bay. It will connect to a small cylinder looking thing. Yank that thing off of it's bracket. Continue to follow that vaccum line to the intake manifold, and remove it. Plug the hole in the intake mani or you will get a vac leak. If I'm not mistaken it's a 1/8'' plug. Once it's off, you will still have the CC throttle cable in your engine bay and through the firewall. Follow it to the firewall and twist the plug counter clockwise until it turns out. Pull throttle cable out.. you're done.
This should take you no longer than 5 - 10 minutes. Hardest part is locating and removing the cable from the throttle pedal if you don't know what to look for.
Old Feb 9, 2009 | 04:07 AM
cinci00si's Avatar
Sweet, im pretty mechanically inclined. just a noob to honda cars but honda motorcycles are another thing thanks guys.
What to use to plug the vacume line??
Old Feb 9, 2009 | 06:49 AM
kaluwa3's Avatar
Go to the parts store and ask for vacuum plugs..
they look like this
http://i4.ebayimg.com/02/i/001/29/8b/7292_1.JPG
Old Feb 9, 2009 | 06:52 AM
cinci00si's Avatar
thats perfect man, thanks
My_Teknique
19
May 2, 2010 09:46 PM
sd_ej1
Dec 30, 2008 09:30 AM
usdmEHboy
Jan 8, 2007 10:42 PM
quik2kSi
Oct 7, 2003 12:54 PM
Greyout
Apr 16, 2002 10:02 PM
