91-92 integra obd0 or obd1??
ok on my driver side door the tag says 7/91 but my title says 1992,
how can i tell if my integra is obd0 or obd1, also i c someone wired in a resistor box ??
motor is b18a1 with ys1 cable trans ?
if its all original it's obd1; it doesn't matter when it was built. all 96 integras are obd2, even the early ones that were built in 95. don't know about the resistor box though.
your car is definately an OBD1. the easiest wat to tell is to look at yor Data link connector. OBDI has a Honda DLC connector. OBD0 doen't exist. I don't know who told you it does. All integras are OBD1 until 1996 when they switched to OBDII.
Well, don't speak to fast! I have a friend that has a 1996 four door LS but it's wired up as a OBD1.
It was a federal requirement that cars sold after 1/1/96 had obd2. While it probably would've been legal if the car was sold as a '96 model year, but in '95, I don't see why Honda would do that. You should verify the model year by checking the VIN. What makes you think the car doesn't have OBD2?
