Type r rim question
Old Feb 8, 2009 | 06:42 PM
crxsleeper210's Avatar
Default Type r rim question
I am recently a new owner of a 93 prelude vtec. I have been wanting to put a set of 96 itr rims on my prelude but i want to know if any mods are needed to install the rims...i heard i might need spacers and new wheel studs...if someone knows for sure exactly what is needed if anything please let me know...i have a set lined up but i want some more info before i buy them..thanks
Old Feb 8, 2009 | 07:13 PM
pprowler6's Avatar
Default Re: Type r rim question
im pretty sure its a direct swap.. stock prelude wheels are +55 offset and itr wheels are +50 if i remember correctly. what else...itr wheels are 6 inch wide and prelude wheels are 6.5 inches wide i think. thats the only difference. someone correct me if im wrong.
Old Feb 8, 2009 | 07:17 PM
Prudz_lude's Avatar
The ITR rims are 6.5 wide. I own a set of them. You need to find the JDM ITR rims though because those are 4x114.3. All the USDM ones are 5 bolt. They are decent rims and look pretty good as well.
Old Feb 8, 2009 | 08:14 PM
pprowler6's Avatar
do the jdm itr rims use tappered lugs or the acorn ones??
Old Feb 8, 2009 | 08:47 PM
ya i am getting the 96 spec itr rims like you mentioned.....so it should be a bolt on and go affair? i dont have to worry about rubbing the calipers or anything? i am asking because i'd rather ask a dumb question then make a dumb mistake lol...sry i know its probably been covered a hundred times already but i looked and couldn't find exact answers. thanks in advance for any help
Old Feb 8, 2009 | 09:24 PM
Prudz_lude's Avatar
I forgot to mention you will need 5mm spacers in the front to clear the calipers.
Old Feb 8, 2009 | 10:22 PM
do i need extended wheel studs too or will stock be ok
Old Feb 9, 2009 | 03:24 AM
white5thgen's Avatar
A 5mm spacer is fine on stock studs but any bigger and wheel studs are a must. Although it can never hurt to get extended studs anyway while your at it for insurance.
Old Feb 9, 2009 | 07:59 AM
pprowler6's Avatar
anybody know what kind of lugs these use???
Old Feb 9, 2009 | 11:08 AM
Prudz_lude's Avatar
As said above, stock studs are fine, stock lugs are fine.
Old Feb 9, 2009 | 04:47 PM
Thx for the info fellas....im going to be using the 5mm spacer on stock studs for now.
One last question...do i need the spacers for the front only or do i need front and rear???
Old Feb 9, 2009 | 05:28 PM
cb9tuner's Avatar
no just for the front you need 5mm spacers you'll be alright in the rear
Old Feb 16, 2009 | 07:25 PM
Quick question...ive been looking for 5mm spacers and i was wondering what you guys recommend??? something cheap like this http://cgi.ebay.com/ebaymotors/PAIR-...Q5fAccessories
Or some H&R or Eibach for $65+
Old Feb 16, 2009 | 08:56 PM
Prudz_lude's Avatar
I was just rocking a set of ebay spacers.
churbor
Oct 28, 2006 11:35 AM
ITR9788
Mar 25, 2005 06:03 AM
ChiNoS
Jul 15, 2003 09:57 PM
done
Jul 8, 2002 01:19 PM
comptechgsr
Feb 24, 2002 07:22 PM
