Failing for high CO
My stock 94 Accord is failing for high CO, the car was putting out .93 and the max allowed is like .62. I can't really figure out why it would be so high.
I think it could be my cat, but it's only 1 year old, so I'm doubting that. I don't see any reason for the motor to be running rich, other then maybe a lazying 02 sensor. I really don't have a money to dump out for a new cat and new o2.
I tried Guarenteed To Pass and it knocked my reading down from .95 to .93, but that was also three days after it was all out of the car. I might try it again to and go to testing with it in my tank.
Any suggestions?
Any suggestions?
I have a SRI, I don't think that it would cause it to run rich, maybe a tad bit leaner if anything.
I was thinking of going back to stock intake for now, but the filter was ruined and my local supply store was out. Would it make that much of a difference? I'm stumped
Do you know how to monitor O2 voltage with a voltmeter? If your O2 voltage toggles at cruise or wherever it fails then your feedback system is working properly and you likely have a bad cat.
I'm not sure how. I'm gonna take a guess and say have somebody bring it to 2500RPM in park, I put the voltmeter to the power wire and see if it jumps?
No, you need to put one lead of the voltmeter on the O2 signal wire and the other to ground. The reading should toggle between 0 and 1 volts pretty rapidly. At what RPM did it fail and what were the readings?
Neither of those will cause it to run rich. Obviously I can't know how your car runs and what direction to go in but I would be suspecting the cat assuming the car runs well. If it came into my shop the first thing I would check was to make sure the feedback system is working as designed and then I would check the cat with my infrared pyrometer. The inlet to the cat should be cooler than the outlet. In most cases a 100 degree F difference indicates that the cat is working properly.
Tomorrow in school I'm gonna take it to the shop and look at it under the lift. I'll see if maybe the bolts are loose or something, which might make a big temperature difference as stated. Also gonna do the voltmeter testing.
Warmed up the car, and it's a 20 minute drive to the inspection station, plus I left my car running while I waited 10 minutes in line. The thing is the cat is 1yr old, the only way I could see it being bad is if I've been running rich since it's been replaced, and it ate the catalyst away.
Usually High CO indicates a rich mixture. what was your HC and NOX at? what was your CO2% at?
usually high CO would be caused by a dirty/plugged air filter, plugged pcv valve, or dirty oil.
yes a bad air filter will cause high CO. Checking voltage on an O2 with a voltmeter is not gonna help you at all, if u want to check you readings on a 02 sensor you will need a oscilloscope or a snap on vantage scanner to check your readings. Voltmeter wont give u an actual reading.
Like I said, if I saw that feedback was working properly the first thing I would do is check catalyst efficiency.
In response though, oil was changed, and the filter was clean. HC + NOX were wayy below MAX limits. I took it back for the third try, and it went with flying colors haha
atlthrasher
Dec 19, 2012 02:38 PM
ketchup
Engine Management and Tuning
Nov 16, 2008 11:56 PM
EGcivicBoy
Dec 13, 2003 09:17 AM
