tachometer
Old Feb 8, 2009 | 02:57 PM
new_kid's Avatar
Default tachometer
think i orginally put this in wrong section so will move to here
Hello all
First post of what will probably be of many as im not the greatest when it comes to hondas
Currently have it all wired in bar the problem below
Can anyone tell me which wire i use from the distrubutor or from the normal clocks to receive the rpm signal for this
http://www.4wheelparts.com/Cobalt-Sh...6&t_pn=AMG6299
Here is the wiring diagram for it
http://www.autometer.com/productPDF/1244.pdf
engine is a b16a2 if that is any help
thanks for any info u can give
Mikey
Old Feb 8, 2009 | 03:02 PM
jdmme09's Avatar
Default Re: tachometer
from what i know is a blue wire on distribuitor.
Old Feb 8, 2009 | 03:07 PM
teamworxek9's Avatar
what ^he^ said is true. You could also find it behind the cluster if you use a volt meter to find continuity. Just put one end on the blue at the dizzy, then check the blue wires behind the cluster. Im pretty sure its a solid blue at the cluster as well.
LilCXHatch
Jun 2, 2019 12:47 PM
krazy newbie
Aug 18, 2010 12:07 PM
BB6racer
Jun 18, 2006 10:29 AM
Adern
10
Feb 3, 2006 08:54 PM
kevoweb
10
May 25, 2005 12:46 PM
