? on which piston to go with
Old Feb 8, 2009 | 01:12 PM
97GSRcoupe's Avatar
New User
Default ? on which piston to go with
I used a stock b18c1 and with srp 9.5:1 and its supercharged on spray compressing it through the charger, ticking noise after 10 passes on a 30 dry shot pulled apart motor after it blew a head gasket and the sleeve was cracked from the top of deck 3.in. down and the block broke. Every piston by the valve reliefs on the intake side were lifted but no rings were butted. Would the cp-sc7012 or the JE 242879 piston be better than the srp? or who knows of a better piston to go with, with a c.r 9.0-9.2 with a 83mm bore. looking to spray a lot more then just a 30 shot,
Old Feb 8, 2009 | 01:19 PM
rota92
Guest
Posts: n/a
Default Re: ? on which piston to go with
I've always ran Wiseco and love them, lot's of other people will tell you the same. Miller from NRGtech can hook you up with his spec piston from them if you'd like
Old Feb 8, 2009 | 01:21 PM
NJIN BUILDR's Avatar
The alloy used in the CP and JE is a little tougher than the SRP.But it doesn't sound like that was your problem.The engine was detonating.You need to be a lot more conservative with your tune.
Old Feb 8, 2009 | 01:43 PM
sgnlab's Avatar
I run cp's and I love them! Not saying anything else wont work just as good but its my only experience with any forged piston!
Old Feb 8, 2009 | 02:53 PM
narfdanarf's Avatar
CP's here. After I tore down my last motor with 26k miles of abuse on it and it still looked minty fresh, I will never run anything else, regardless how well anything else works. I will stick with what I know works flawlessly.
Old Feb 8, 2009 | 04:02 PM
turbotypeR@SPEC's Avatar
25 Year Member
CP pistons here. Very happy with them
Old Feb 8, 2009 | 04:12 PM
RedneckRicer's Avatar
Caston i told you get those Wiesco's..lol
Old Feb 9, 2009 | 08:31 AM
ssc_thomas's Avatar
Regardless of your piston choice you’re going to have the same problem. You said your app is supercharged? I'm guessing you’re using an FMU to raise fuel pressure (uses vacuum to raise fuel for boost). If that is the case running a dry nitrous shot isn't going to work (also uses vacuum to raise fuel pressure). You’re going to need to use a wet shot for the nitrous or take control of the way your fueling for boost from the supercharger (I.E. stand alone). After you address this issue (the reason for detonating) go with JE, CP, or Wiesco pistons. All are really good right off the shelf!
Old Feb 9, 2009 | 11:05 AM
DSRxCandyh2bEG's Avatar
CP Pistons here as well.
Old Feb 9, 2009 | 11:11 AM
No he isnt using a FMU. he is using Crome. hopefully we can get miller out here to tune and Hondata will be installed
Old Feb 9, 2009 | 11:42 AM
SPOOLINmatt's Avatar
Arias
Old Feb 9, 2009 | 12:26 PM
97GSRcoupe's Avatar
New User
I was surprised to see the ring land to lift, it was 11.5s on the spray tune up pulling 11 degrees on 12 lbs of boost, but it could be the junk srps
Old Feb 9, 2009 | 12:39 PM
might have been in the tune too man. some people have bad reviews of crome. mainly on ignition mapping.
Old Feb 9, 2009 | 12:51 PM
MrParks's Avatar
i have used all the above, and had great results with all of them.
but i choose to run arias pistons. great service, quality parts, proven performance.
Old Feb 9, 2009 | 12:52 PM
extralargenog's Avatar
c
p
Old Feb 9, 2009 | 12:54 PM
DaveF's Avatar
any pictures of the plugs ???
Old Feb 9, 2009 | 01:00 PM
also he said that hat he was using heat range 10 plugs. thats what he said when i spoke to him on the phone. that seems a bit Extreme for his setup
Old Feb 9, 2009 | 01:02 PM
Donker15's Avatar
+1 for CP
Old Feb 9, 2009 | 01:56 PM
Garcia-Racing's Avatar
+2
Old Feb 9, 2009 | 02:19 PM
UJLSMoFo's Avatar
From: east coast performance and tuning, jacksonville, nc
sound like your tune. i seen a lot of nitrous car lift ringlands. fuel is is getting under the ring and igniting causing them to lift, but ive used all makes of pistons and wiseco for me.
Old Feb 9, 2009 | 02:42 PM
streetracer6rpt's Avatar
Originally Posted by SPOOLINmatt
Arias
x2
dgie
Jul 9, 2008 09:01 PM
got wide
Sep 4, 2007 03:55 PM
si_bat
Jun 24, 2007 05:11 PM
VtecbOi
25
Nov 1, 2005 06:43 PM
earl
Apr 29, 2002 06:05 PM
