Suspension & Brakes Theory, alignment, spring rates....
Eibach sways require Brace on EG???
Old Feb 8, 2009 | 12:12 PM
iliv2xlr8's Avatar
Default Eibach sways require Brace on EG???
Hello all,
I just put my suspension together on my 93 hatch and I am waiting for my Eibach sways. They are on back-order. After reading around, I noticed that a lot of people recommend a sub-frame brace when upgrading, due to tear.
My question is, Would the Eibach sways need reinforcement? The bars are 26mm front and 17mm rear.
I was considering getting the Beaks kit as assurance, but I wasn't sure if it is necessary.
Thanks all,
-XLR8
Old Feb 8, 2009 | 12:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Eibach sways require Brace on EG???
I would, just to be safe, even though it's only 3mm larger than a stock GS-R rear bar. If you don't use something like Beaks, then your only mounting option would be the GS-R's OEM sway bar bracket mounts, which could cause problems. The Beaks kit gives you a flat surface on the subframe to which you can attach the sway bar's D-brackets.
Old Feb 8, 2009 | 12:37 PM
iliv2xlr8's Avatar
Thanks.
After looking at the kit, I noticed it has a mount included. Would the Beaks kit work with this? Would it still be necessary?
Thanks.
spideymangDC4
Northwest (Sales)
Jun 25, 2010 11:34 AM
BlackShingo
Suspension & Brakes
May 14, 2010 05:33 PM
AutoXer
12
Jun 16, 2005 02:59 AM
Kev95lx
Sep 26, 2003 05:54 AM
fasthonda
May 13, 2002 03:17 PM
