Idle question (iacv plug?) em1
Old Feb 8, 2009 | 12:08 PM
taimysho0's Avatar
Default Idle question (iacv plug?) em1
hello im having idle problems on my EM1 and i read the DIY : https://honda-tech.com/forums/showth...highlight=iacv
however, i cant find the IACV screw to set it to 800rpm according to the reading, i cant even find the IACV plug, if any1 can tell me where its located on an EM1, id appreciate it. thanks!
ps. the problem with my car is soemtimes it idles at 2000 or sometimes it idles at about 500 and usually never in between. this has been recent, it normally idles around 800rpm.
Old Feb 8, 2009 | 12:15 PM
trustdestruction's Avatar
Default Re: Idle question (iacv plug?) em1
the idle adjustment screw is on the passenger side of the throttle body
i think you should start by cleaning the IACV. There's no reason to mess with the idle adjustment screw.
Old Feb 8, 2009 | 01:06 PM
taimysho0's Avatar
i see, where is the IACV loacted? i dont wanna take apart the wrong part.
Old Feb 8, 2009 | 01:08 PM
on the back of the intake manifold
Old Feb 8, 2009 | 01:13 PM
SI_frankenstein's Avatar
Its right behind the intake manifold, actually its bolted on to the back of it and has two coolant hoses attached to it.
james007
Apr 30, 2010 04:26 PM
Tizzakowack
Nov 18, 2008 07:10 PM
wilrock
Apr 4, 2006 05:56 PM
SHG_EasyE
Apr 2, 2006 08:10 PM
AlxSiR7
Feb 1, 2005 11:42 AM
