IAT Connector Wiring quick question
Okay so the IAT connector had really bad continuity, it would only work for like ten minutes if i sprayed electronics cleaner in it. So i took it apart to fix it, in my stupidity i forgot to look which wire goes where. So if somebody knows or could look at their car and tell me which wire is on the top side on mine there is a red/ yellow wire (which goes to the ecu) and green/white. Maybe it doesn't matter but i don't want to find out the hard way.
93 civic coupe ex, although i don't think it matters cause i think it is the same wiring colors for most models, i connected it with red/yellow on top because i have a vague recollection of that bein how it was. Also i google searched and someone had a picture where i could see it like that. But if that is not right please let me know. thanks
i googled it and yea. your right.
you got it
and it matters what year the car is cuz sometimes the car maker changes wires on cars with different years
like 92-95 might be different that 96-00
you got it
beefjerky
14
Oct 1, 2006 07:09 AM
