88-91 Si distributor pinout needed..
I have an Si 88-91 Crx distributor that I repinned on to a DX connector, and now I need to repin it back. Can someone tell me the location where each color wire goes to in the 8 wire plug ? The help would be greatly appreciated. Thanks in advance guys.
IF for whatever reason you were to need to rewire your EF distributor plugs here is how they are set-up.
Look at the back of the plug, if you have it oriented right then you have the tab at the top, then one row of two wires, one row of four wires (with the leftmost one empty), and one row of two wires. Reading left to right and top to bottom you get:
WHT/BLU (C4 at ecu) TDC sensor
ORA/BLU (C3) TDC sensor
Empty
WHT/RED (B12) Crank angle sensor
ORA (B10) Crank angle sensor
BLU/GRN (C1) Cyl sensor
BLU/WHT (C2) Cyl sensor
Empty
Yuta
Oct 13, 2018 08:07 AM
crxnonvtec
Aug 28, 2009 11:12 AM
BRAWDY03
May 13, 2004 04:50 PM
powerLINEinteg
May 6, 2003 07:57 AM
89 CRX SI
27
Jan 20, 2003 04:12 PM
