Worth buying?
Old Feb 7, 2009 | 05:27 PM
en00be's Avatar
Default Worth buying?
Ok so i have a 95 eg sedan with an LS swap. It has I/H/E and staged clutch, i was thinking about getting a hondata intake mani. gasket since i have like 50 bucks to spend. My question is would it be worth getting? or is there anything else i could buy for around 50-70 bucks that will increase performance. Thanks alot!
Old Feb 7, 2009 | 05:31 PM
iamthefollower's Avatar
Default Re: Worth buying?
from what I have read on the hondata intake gaskets, they are supposed to be dyno proven to give you like 7hp...
Old Feb 7, 2009 | 05:38 PM
en00be's Avatar
i was thinking if i dont get this i would chip my ecu is there any with check engine shift around 7k and launch control?
Old Feb 7, 2009 | 05:56 PM
joelmatt89's Avatar
checkout phearable.net i think they might have what your looking for
Old Feb 7, 2009 | 07:26 PM
en00be's Avatar
Thanks so much dude
i just bought some stuff off there!
Old Feb 7, 2009 | 07:38 PM
JDM-JAMES's Avatar
get the ecu chipped
Old Feb 7, 2009 | 07:39 PM
en00be's Avatar
how much will u charge i just bought the chip
Old Feb 7, 2009 | 07:47 PM
JDM-JAMES's Avatar
Sent you a message
Old Feb 7, 2009 | 07:58 PM
mizzoEG's Avatar
Someone please fill me in here..
How exactly does an intake manifold gasket result in any kind of horsepower increase?
Old Feb 7, 2009 | 08:19 PM
JDM-JAMES's Avatar
The hondata gasket blocks the heat from the head so basically your blocking the heat transfer from the head to the manifold colder manifold= colder air = more power
it wont make your manifold ice cold but it will lower temps
pcguy760
Apr 13, 2011 11:08 AM
bankston5thgen
17
Feb 24, 2007 07:57 AM
pny1981
Nov 16, 2005 12:06 PM
Reelizmpro
Oct 5, 2004 01:11 PM
Rod.
Jul 28, 2004 12:35 PM
