Changing QP's on a 94 TEG. PICS
Ok so I bought a 94 Integra GSR for a really good price. Come to find out whoever had it b4 me was ghetto and cut the wheel well lip out on the rear QP's. Not a good idea since there starting to rot there now. So I decided to change the entire QP's Instead of a hack Fiberglass or Bondo job. I will add pics as I make progress. This is not for the weak of heart. Tools required are listed below
4.5" Grinder
Cut off wheels
Wire wheel
4-6 Spot weld cutter tools
4-6 Very small drill bits
Drill
Prying screwdriver
Lots of light
Patience
Razor Knife
Sawzall
Leather gloves
Lots of room
4.5" Grinder
Cut off wheels
Wire wheel
Drill
Prying screwdriver
Lots of light
Patience
Razor Knife
Sawzall
Leather gloves
Lots of room
man you know you can buy factory replacment panels for probably the same amount you got invested in those used panels especially when you factor in the time in prepping the used panels. and when you use a spot weld cutter your not supposed to drill a hole all the way through the panel. you just cut the weld and then use a panel knife to separate the two if you need to. and why waste money on type r doors when all you would have to do is weld up like six 1/4" holes in each door? you could do it in an hour easy.
haha an hr a door ya ok. Better off just to get type-r doors not have to do any welding and filling. I guess you havent done much body work. Or if you have it was half assed. Factory QP's are about $900 for the pair so for the $200 I have invested in these type-r quarters I think its a pretty good deal. And as far as the spot welds go I would much rather just drill all the way through and not have to worry about having trouble reinstalling the new panels. When u use a spot weld cutter and dont cut all the way through your left with that circle still spot welded to the part. That makes for a pain in the *** when you go to reinstall the new part.
yea your using the same one i was.at the time i was getting mine from eastwood and the local body supply.then sometime after that harbor freight started selling them for way cheaper.
last time i checked those panels werent $900 but i could be wrong maybe the r's are more since they have all that extra metal in them, but if it was cheaper to use used panels i would think the acura body shop i work at would use them instead of getting new ones.
as far as the spot cutters go, yeah you should cut through the used replacement panel you are using which is just how the new replacement panels come. what i was referring to was the panels you are removing from the car, you cut all the way through leaving you with a hole in the spot you would normally weld the replacement panel to. what are you going to weld the replacements to now.
spot cutters have and serve a purpose and so do panel knifes and if your just going to DRILL all the way through the welds why are you wasting money on cheap spot weld cutters that you are burning through when you could just use a DRILL BIT?
Usually what I do to get panels off of a car is grind down the welds. Esspecially on a quarter. Saves so much time cause I do not have to use a spot weld cutter and then grind down the remaining material, and I don't drill through were I will be welding.
The problem with drilling through like you did and using a used quarter is that the welds on both quarters are most likely in the same spot. You may have to make new holes and weld those instead and then fill the other holes with weld. You do not want to try to fill that many holes because in the advent of an accident, that quarter will not do any good seeing as the welds are only really tacked in if the holes all lined.
Maybe I explained that well enough. Well good luck with it all.
This is all coming from a guy that works at a production body shop. Talk to me when you work at a high end custom shop, thats not all about getting it out the door so they can collect the insurance check. So anyways the holes def dont line up on the new to old qp's and new qp's are $900. As far as welding the holes up in the doors, I can def do it but with the time involved I would rather just get a set that didnt need to be shaved. Color doesnt matter and why is this a pissing contest anyways. No wonder Honda-Tech has such a bad rap. Its from *ssholes like you that make ppl not want to post here anymore
yes sir. this is exactly what i was trying to tell you.
it wasnt a pissing contest untill you accused me of doing half assed work. just because i work at a body shop doesnt mean i dont do custom **** on the side either (my personal car has an all steel wide body). i wasnt trying to be an ******* and i really dont think i was. i was trying to help you out so you didnt have to waste unnessisary time and money and also help the future readers of this post so they dont do it the wrong way ( aka, your way)
you are doing good work. i dont go all the way through on my spot welds either, you dont always have a backing to weld to when you go that route. i drill out the welds and use a panel splitter. i even put a wege in the spots i can so the spot welds pop when im through. then just grind off the tabs, no worry about not havng a mating surface.
hate to dig this up but do you have any pictures of the rear panel section that goes inbetween the two quarters? thats what i have to replace on my car
Slo Honda Driver
Aug 12, 2008 09:01 AM
