EG clock problem
Old Feb 7, 2009 | 11:06 AM
en00be's Avatar
Default EG clock problem
So the clock in my eg sedan only works when i hit the button to brighten it up (button all the way to the right) what could be the problem , ive tried dif. clocks by the way.
Old Feb 7, 2009 | 11:35 AM
Nemetz's Avatar
Default Re: EG clock problem
Clock show correct time or get off?
Old Feb 7, 2009 | 05:53 PM
en00be's Avatar
its off. it resets to 1:00
Old Feb 7, 2009 | 11:10 PM
Nemetz's Avatar
Hours or something else do not work only? To begin with it is necessary to check up a fuse.
Old Feb 8, 2009 | 12:53 AM
White95SiHB's Avatar
Pop your hood, then open up the fuse box by the battery. Check the fuse labeled 'back up'.
I had the same problem, but in addition to the clock problem my stereo wouldn't work. Both the clock and stereo started working after I replaced the 'back up' fuse.
Do you have a stereo in you car, and if so, is it working?
Old Feb 8, 2009 | 04:23 AM
Scotty Dosent Know's Avatar
white 95 is right the clock will light up by pressing but not keep time if your backup fues is popped. also stereo will not keep presets. Alot of the time monkeying with the stereo will pop this fuse.
Old Feb 8, 2009 | 05:40 AM
Nemetz's Avatar
/I had the same problem, but in addition to the clock problem my stereo wouldn't work. Both the clock and stereo started working after I replaced the 'back up' fuse.
The matter is that the stereo can be connected not from regular conducting and, for example, from the accumulator directly. Then the stereo will work at a faulty "back up" fuse.
Old Feb 9, 2009 | 10:44 AM
en00be's Avatar
that makes sence cuz my stereo dont work
Old Feb 9, 2009 | 11:11 AM
Nemetz's Avatar
Then 99 percent that are a "back up" fuse . Is under a cowl, at the left, near the accumulator.
Old Feb 10, 2009 | 09:22 PM
en00be's Avatar
Lol
Found out it was that fuse thanks guys!!!
kirkland08
Jun 17, 2010 09:12 PM
FillDirty
Jul 14, 2008 12:39 PM
asianalbutt
Sep 28, 2005 04:21 PM
A.S.I.M.O
Nov 20, 2004 07:21 AM
vtecdc2
Jun 16, 2003 02:23 PM
