91 acco. ex auto tranny question
quick question, ive noticed over the month that when i switch from D4,->Park, or even Park->D4, its not smooth, u can def. feel it, driving is completely fine, is my tranny hurting?
Honda uses the same cable for all model Accord Automatics of that year.
Make sure that all your Engine grounds are intact (give it a cursory inspection). I had one case where a customer had some engine work performed and someone forgot the Ground Strap / connection. Not to worry, it started and ran great for about a year, until one day the Trans control cable failed. What happened?
The Engine found a ground path thru the transmission Control Cable and worked fine 'till one day the shieth melted and one of the metal ends popped off
P
