Help: CEL Code 90 on newly swapped '98 GSR into '00 CX Hatch
Old Feb 7, 2009 | 10:36 AM
Si_Allen's Avatar
Icon2 Help: CEL Code 90 on newly swapped '98 GSR into '00 CX Hatch
Hello,
After getting the code I did some searches and found out that most of the time this problem occurs because of a loose or faulty gas cap. Since I just got the car back from having the swap completed, I checked the gas cap and found it had been loosened so I figured I had solved problem. After resetting the ECU and tightening the cap I drove for a day or so and the CEL returned with the same code.
I also read that you can take it to a shop and have them put some colored gas through the lines and so forth to check for a leak in the evap system. But, I would love to figure this out without putting anymore money into the car, since I just forked out the money for completing the swap.
Can anyone let me know if there are some other things I can check before taking it into a shop?
Thanks,
Allen
Old Feb 7, 2009 | 06:52 PM
Si_Allen's Avatar
Default Re: Help: CEL Code 90 on newly swapped '98 GSR into '00 CX Hatch
up
Old Feb 7, 2009 | 08:02 PM
GSR44's Avatar
go buy a replacement gas cap from autozone
Old Feb 8, 2009 | 06:41 AM
Si_Allen's Avatar
I am pretty sure it isn't the gas cap. Since it was working before the swap and the light only came on the day I got the car back. I will check into it though. Bump.
Old Feb 8, 2009 | 03:40 PM
stock88crx's Avatar
There is a leak somewhere within your EVAP system. Sometimes is loose gas cap, but if its not, it may have something to do with the black charcoal box in the engine bay. Did you remove it from the civic CX? if not, did u connect all the correct lines to it?
I found the resolution to this problem is to run a OBD1 ECU. Problem evaded/solved.
Old Feb 8, 2009 | 03:53 PM
paton5g's Avatar
Take it back to the shop that did the swap. Maybe they didn't hook up something. I don't know how much you spent but probably in the thousands. For that kind of money they can at least diagnose the problem for you for free.
Old Feb 9, 2009 | 04:57 AM
Si_Allen's Avatar
I really got a great price, $2800 for the motor and installation. I know the guy is busy and also lives an hour away so I am trying to figure it out on my own first. I am going to see if I can have him look at it again when he has time. Car is running great it's just that damn check engine light is so annoying to look at.
elnoyl
Honda Civic (2006 - 2015)
Aug 29, 2021 07:26 PM
northworm
Nov 10, 2007 09:24 AM
teler86
12
Feb 20, 2007 01:46 PM
96AccordEX
Mar 11, 2005 07:37 PM
scootrrydr
Sep 30, 2004 09:55 PM
