d16z6 del sol auto to manual swap
Old Feb 7, 2009 | 08:49 AM
Kenneth Curry II's Avatar
Default d16z6 del sol auto to manual swap
I have a 93 del sol si with the d16z6. it is auto and i want to go to a manual. What parts do i need and can i use a wrecked civic for the parts?
Old Feb 7, 2009 | 08:56 AM
White95SiHB's Avatar
Default Re: d16z6 del sol auto to manual swap
I'm pretty sure you'll need a shift linkage from a Del Sol Si.
Old Feb 7, 2009 | 01:06 PM
dreamer_lokdelsol's Avatar
only civic's fit on the sol's?
Old Feb 7, 2009 | 01:30 PM
98civdx's Avatar
Master Detailer
shift linkage from a Del Sol Si IS required.
edit- i dont think it matters if its an si tho
Old Feb 7, 2009 | 01:58 PM
94EG8's Avatar
Seagull Management
S or Si will both work.
Old Feb 8, 2009 | 10:18 AM
Orangedragone's Avatar
Yes, potentially you can used a wrecked civic for parts.
You will need...
-5 speed transmission. obviously . any D series should fit.
-Shift linkages. From any SOHC delsol.
-Shifter. Obviously.
-ECU. From a 5 speed for a d16z6. Others may work, altho specific to d16z6 would be best.
-Pedal assembly.
-Hydraulic clutch line assembly. I'm pretty possitive all delsols are hydro trannys.
Also, i really want to add harness to this list but I herd somewhere it doesn't make a difference.
Old Feb 8, 2009 | 10:34 AM
acidburn2k2's Avatar
also you need the rear L bracket and mount. and the top tranny mount. now the top tranny mount on a 5 spd tranny will not fit into the bracket on the frame so you will have to gt the hasport auto->manual top tranny mount which has the offset in it.
one of the most important things that were not mentioned:
master cylinder
slave cylinder
Clutch, P/P and flywheel
new flywheel bolts (the auto ones are diff then the manual ones)
new inspection plate (not really mandatory)
new starter
in the hydraulic line assembly, one of the most important parts is a coupler that connects the left side of the hydraulic line assembly to the right side (left side = master cylinder to coupler, right side is coupler to slave cylinder)
new shift boot (this is just for looks)
Old Feb 8, 2009 | 10:35 AM
oh and ofcourse all the bearings that come with it, also make sure you put some new axle seals int eh tranny before you install it all
Old Feb 10, 2009 | 12:46 PM
So basically a wrecked civic will work minus the linkage?
Old Feb 10, 2009 | 01:52 PM
98civdx's Avatar
Master Detailer
pretty much the lines may be different.
ejv8s10
Sep 3, 2014 11:52 AM
trontek89
May 28, 2014 07:22 PM
jakeypoo12
Aug 14, 2008 06:52 AM
tambara
Nov 29, 2006 07:00 AM
tambara
Oct 24, 2006 09:05 PM
