CA smog refs
Old Aug 8, 2002 | 02:28 PM
THE *FOB* MOB's Avatar
Default CA smog refs
i have an 89 crx si which hasn't been running for 'bout 2 yrs. now....i want to drop a D16y8 engine.....the engine is a US engine, so i should have no problem with it passing smog....right?.....couldn't i just get it smoged to register it.....or do i need to take it to the refs because it's been non-operational for 2 yrs.....thanks
Old Aug 8, 2002 | 02:38 PM
Spade's Avatar
Default Re: CA smog refs (ssr265)
You need to get it smogged to register...
Yes, you can drop the Y8 in there. I suggest smogging it as a 95 engine no later. That way you can run OBDI otherwise you will have to upgrade (downgrade performance wise) to OBDII.
Just purchase a Z6 it makes it easier...unless you already have the Y8.
Oh, and the JDM engines are legal too.
Spade who has a JDM (big deal) Y8 in his Civic.
[Modified by Spade, 3:39 PM 8/8/2002]
Old Aug 8, 2002 | 03:13 PM
Default Re: CA smog refs (Spade)
so the JDM b16's & zc's are legal?.....thanks man....i'm planning on running off the p28 ecu which is also obdI(?)......so wtf are smog refs for then?
Old Aug 8, 2002 | 03:39 PM
Spade's Avatar
The smog refs makes sure you using the correct ECU with the correct engine and that nothing over deemed "illegal" is used on the car....
Make sure your engine and everything has either stock stuff or CARB equipment on it.
They will also ask for documentation on the ECU and engine to make sure you are using the correct one.
EDIT: JDM engines must have USDM equivalent smog equipment. 99 JDM B16 Must have 99 USDM smog equpiment for the B16!!
[Modified by Spade, 4:39 PM 8/8/2002]
Old Aug 8, 2002 | 04:36 PM
cool! man thanks for the info .....then i should be ok with the y8 p28 ecu then.
radicaled434
Apr 26, 2008 12:49 PM
aho
Dec 7, 2005 12:42 PM
FalkenSiR
14
Aug 12, 2005 02:52 AM
crashtest Sonny
Apr 30, 2003 07:31 PM
