Suspension & Brakes Theory, alignment, spring rates....
Koni yellow + gc coils = rough?
Old Feb 6, 2009 | 09:47 PM
koulaid's Avatar
Default Koni yellow + gc coils = rough?
i have the koni yellow struts and gc coils. all 4 gc top hats all around. its on the softest setting on all four. why does it still feel rough whenever i hit a bump? could it be my tires? its lowered and has one finger gap on all 4.
Old Feb 6, 2009 | 09:53 PM
kaiba's Avatar
Default Re: Koni yellow + gc coils = rough?
Originally Posted by koulaid
i its on the softest setting on all four
The problem lies there.
Old Feb 6, 2009 | 10:27 PM
owneyboy's Avatar
i had a similar problem do you have your shock covers on? those things messed up my gc's and made the ride very uncomfortable (black tubes)
Old Feb 6, 2009 | 11:18 PM
koulaid's Avatar
so i should set it to medium-hard?
Old Feb 6, 2009 | 11:19 PM
koulaid's Avatar
no shock covers
Old Feb 7, 2009 | 05:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
What are your spring rates? They're going to be stiffer (much stiffer) than stock, which in turn results in a rougher ride than stock, no matter what the shock rebound damping is set to (compression damping is always the same on Koni Sports).
Old Feb 7, 2009 | 07:28 AM
unusual71's Avatar
the only adjustment on these shocks is rebound damping. that is how fast the shock returns to its rest position after being compressed. since koni's are known for being very good dampeners in this set up its probably just the fact that the springs are now much stiffer like pat said. these shocks are good with springs up to and around 500lbs/in i believe.
Old Feb 7, 2009 | 09:52 AM
DcLs's Avatar
yea my car is like that too, drop 2in all around. the ride is kinda rough everytime i go over a bump but the rebound on the shocks absorb it so fast i dont feel my car jumping up and down that much.
Old Feb 9, 2009 | 04:41 PM
koulaid's Avatar
thx guys. i adjusted the setting to half way on all 4. now it rides better and softer!
Old Feb 9, 2009 | 05:26 PM
Tyson's Avatar
did you reuse the dust boots? you shouldnt have.
but new springs will always feel more "rough" than stock. you get used to it.
Old Feb 13, 2009 | 02:49 PM
soupE__'s Avatar
kou i love you
bopbop93030
Suspension & Brakes
Jan 19, 2009 05:14 AM
chris3k
Nov 13, 2007 11:10 AM
jli18
Suspension & Brakes
51
Nov 30, 2005 06:04 AM
Myh4tch
21
Jan 20, 2004 04:15 AM
shpae
Dec 17, 2001 10:18 PM
