emma under construction(my hatch build)
got this car for my 17 birthday in june of 07. did the normal wheels tires and suspension upgrades shortly after. i then found a 92 LS teg for 250 so i bought it for the motor trans and other swapable parts. the first winter i had the car i noticed some bondo work startin to pop. in feb of 08 i started tearin in to the hatch. for the record this is my first project car learning everything as i go thanks to honda-tech and some helpful friends.so on with the parts list and pics.
*car*
1995 cx hatch
*motor*
b18a1
ctr pistons
stock rods w/arp bolts
balanced rotating assembly
arp main and head studs
cometic HG
crower 404 cams
crower dual springs w/ ti retainers
3 angle valve job
mild p an p
ge cam gears
hondata IM gasket
blox IM
blox TB 68mm
presicion turbo 440 injectors
b and m FPR
hasport mounts
*tranny*
cable YS-1
LSD stage2 6 puck clutch
hasport cable/hydro conversion
*suspension*
tokico illumina
tokico springs
energy suspension bushings
skunk2 camber kits f/r
skunk2 LCA
homemade adjustable toe links
*brakes*
*front*
fast brakes 11" adapters
integra calipers
axis ultimate pads
vw corrado rotors
ss lines
*rear*
disk conversion
ss lines
now the pics
d15b8 out
11" big brakes
rear disk conversion
motor back from the machine shop
motor ready to go in
motor in bay painted and wire tucked
stay posted will update as progress continues
*car*
1995 cx hatch
*motor*
b18a1
ctr pistons
cometic HG
crower 404 cams
3 angle valve job
mild p an p
ge cam gears
hondata IM gasket
blox IM
blox TB 68mm
b and m FPR
hasport mounts
*tranny*
cable YS-1
*suspension*
tokico illumina
tokico springs
skunk2 LCA
*brakes*
*front*
integra calipers
axis ultimate pads
vw corrado rotors
ss lines
*rear*
disk conversion
ss lines
now the pics
d15b8 out
11" big brakes
This is in the wrong forum, it should have been posted here: https://honda-tech.com/forums/forumdisplay.php?f=1
The ALL MOTOR Forum is supposed to be a TECHNICAL forum, which this thread clearly is not.
whats this sensor and can i eliminate it from my harness
when i was building my harness i didnt know what it was so i just kept it
Damn good to see someone willing to go to the proper length to repair rusted panels. Damn good for a first timer. You should do something about the rust on the underside of the car as well.
*UPDATE*
need to pull motor and tranny back out. when i went to put my axles in i discovered the tranny has bad diff bearings. so gonna rebuild the tranny whoknows what else i might find when i open it up
heres the pics of under car rust taken care of
Can you post some pictures of your cable/hydro conversion on the tranny? I have to do the same thing and I've been curious about what kind of pieces are involved. Thanks.
thanks to everyone whos complimented my project
Looks great. I'm impressed at the patch work. BTW which weld did you use, Mig or Tig? Also, for cutting what did you use?
nice work. Aren't those inner fenders a bitch?? I wish some body panel company would stamp those out. They'd sell the **** out of them.
Did you use the magnets out of an old set of speakers to hold the wheel arches in place ??
*UPDATE*
motor and tranny are back out gonna crack open the tranny soon to see if there is anything else bad other than diff bearings
heres the pics of the cable to hydro conversion that kp wanted
Death to rust.
