b20 into 90 integra ls, silly questions
Old Feb 6, 2009 | 06:09 PM
spiderrey's Avatar
Default b20 into 90 integra ls, silly questions
car blew head gasket and trans has 2 bad gears. my solution, install high compression b 20 with b series trans. i understand the flywheel i have will work, and ill need to use my intake manifold and dizzy when i reinstall it in the car. just wondering if i can hook up my air and power steering to this new set up. is there anything else that ill need to change? later itll be converted over to v tech.
Old Feb 7, 2009 | 07:27 AM
BoltonGSR's Avatar
Default Re: b20 into 90 integra ls, silly questions
You have a lot to learn. Its not vtech, its vtec.
And yes, you can transfer everything over from the ls integra including PS and AC
Old Feb 7, 2009 | 10:53 AM
gsrb20z's Avatar
ha
Old Feb 8, 2009 | 03:50 PM
spiderrey's Avatar
wow, i guess it shows, im not a honda guy. im a fiat guy. but now ive got 5 honda motors out back , 3 are swaps and ones getting put back together for my younger sons 95 integra. thanx for the info.
i was hoping to get the driveline out of the 90 integra today, but the drivers side axle and the crank nut on the b 20 killed the day. couldnt break um loose. very frustrating.
Old Feb 9, 2009 | 11:06 AM
spiderrey's Avatar
is the crank pully bolt normal or reverse thread? got the axle nut off. this is my last hurdel before actual swap begins. thanx guys
Old Feb 9, 2009 | 11:37 AM
Bl6da9's Avatar
Crank Pully bolt is normal tread.
Old Feb 9, 2009 | 11:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
B20 engine in an Integra is illegal in California, due to it being classified as a "light truck engine", since it only came in the CR-V.
Most cops or inspection stations know to look for it (the B20 block code) and will bust/fail you immediately for it.
Old Feb 9, 2009 | 11:57 AM
delbert's Avatar
wow is it illegal in cali? wtf..my guy has a b20/vtec in cali he bought it in cali i mean and shipped it here and shipped it back down there and he's in the national guard so yeah..
spiderrey's Avatar
thanx for the info on the bolt thread, and yes i know about the legality.. thanx. one more question. i was just about to torque the head down on my sons 95 integra, nevermind, just figured it out.
Old Feb 9, 2009 | 12:00 PM
Community Builder
If the car is not registered in CA then there are no issues. It's only when you try to register a car in CA and get it BAR'd does it become an issue with a B20 swap.
Old Feb 9, 2009 | 12:56 PM
spiderrey's Avatar
thats exactly why i play with old cars. no real rules. the b 16 b in my 74 x wouldnt fly in a newer car, even more so after i swap a 2 liter block under that head.
Old Feb 9, 2009 | 05:11 PM
spiderrey's Avatar
gave up, couldnt pull the motor out the top. tommrow morning ill drop it and lift the car over it.
Old Feb 11, 2009 | 07:48 AM
spiderrey's Avatar
2 questions on this swap. the 90 inegra ls engine has a brass looking switch on the intake side about center of the block, with two nipples. what is this for. there is no where on the other block to install it. also on the replacement block, in the same area, there is a large allen plug that i need to remove to install a sending unit from the b18 block. does anyone know what size allen i need to remove this. thanx
calebbo
Nov 28, 2014 04:42 PM
Azuremen
Transmission & Drivetrain
10
Mar 22, 2009 07:02 PM
Jason703Racing
Sep 3, 2008 01:41 PM
jmcfkya
Sep 25, 2003 05:38 PM
