help.. losing power!!
ok ,,, i drive a 93 del sol... and yesterday was raining on the city.. and i went just into a flooded street, and thanks god i came out good of it...
but the next day. i mean today, when i started driving i felt that my car lost power, the engine still running good and sometimes i drive fine, and sometimes that car simply just lost power and it doesn't matter if i change gears i still lost power, and i keep pressing the gas to get the rev. up and after pressing several times it looks like something just pop out off the muffler... also the moffler does not sound the same. it sounds like clogged!
i wonder if is that water got into the trany. or water got into the catalytic because, it does it after i got more that 15 minutes driving on the road.
any suggestions? welcome
You could of sucked up water. I would change your oil, spark plugs, plug wires, cap and rotor. I would run seafoam before you change your oil also to clean out the carbon build up.
You also might need to change your o2 sensor. Good Luck
OP, do you have a CAI?
by the way. i saw dirty water coming out of the muffler!!
The stock airbox could of also sucked up water, anythings possible. With the water levels he was driving it, I wouldn't doubt it that he sucked up water.
the dirty water is just the carbon that is in your exhaust system. so its no biggy. in fact it SLIGHTY cleaned your exhaust piping. but yea. i would DEFFINATELY remove the cat and make sure water isnt in there. i would also check your O2 sensors
Time for a tune-up
Cap/Rotor
Oil
Oil Filter
Spark Plugs
Spark Plug Wires
o2 Sensor
(I would recommend running seafoam also. Put it in before you start your tuneup. Run it for about 10 miles then change your oil and start the tune-up.) Good Luck
EVERY 1 i have talked to about their car being hydro locked didnt suck up much water.
so i can not understand how your car didnt hydro lock. that is if a high amount of water was even sucked up
EDIT:
i have read a **** load of post about how ppl hate seafoam. how it messed up their gaskets. how it ruined their engine. so i DO NOT recommend seafoam
i'll go with the tune up... by the way how do i check if my 02 sensor is bad or ok... i know where is located. and how to changed it but need to know the procedures to check the 02 sensor!!
im not sure how to check it. but you can just hook up your car to an OBD1 diagnostic reader and see if it throws any codes for the o2 sensor.but i would still change it either way
i do not know how that can be possible.
EDIT:
seafoam = bad!!
EDIT:
seafoam = bad!!
