brake prob. need help
the brake pedal slowly eases to the floor about 1 in 4 stops. someone said its the booster but i did the check it said in the haynes manual and it seems fine? is it my master cylinder
the only thing thats been done so far is a valve cover gasket kit. but i just bled the brakes about three times over. it got stiffer but still sinks to the floor.
Bench bleed the new master by plugging the outlets, filling it with fluid and pumping till it gets hard. Then install it in the car.
before you go and replace the whole master, get yourself a new cap it could just be a problem with the gasket in the cap. Also check your vacume line to the booster maybe its dry-rotted.
Mandeep
Aug 17, 2005 06:23 PM
