97 Civic Misfire
Old Feb 6, 2009 | 01:05 PM
JD97EKCivic's Avatar
New User
Default 97 Civic Misfire
I have a 97 Civic with a Y7 block and a Y8 head. When I first start up the car, it idles fine but when I give it gas you can hear a misfire. When I'm cruiseing down the road and I barley give it any gas, it will run fine. But when I give it just alittle more gas, it will miss like crazy. The CEL will flash but as soon I as back off the gas, it will run fine but the CEL stay on. The only code Im gettin is for a misfire in cyl 2. I changed the plugs, wires, car rotor and I even tried the injector. It feels like im running out of gas but its only happening in one cyl. Any ideas?
Old Feb 6, 2009 | 01:09 PM
Former User's Avatar
Default Re: 97 Civic Misfire
Check the compression in all of the cylinders. Cyl 2 may be low.
Old Feb 6, 2009 | 01:15 PM
New User
would that cause it to happen only under load? After I've been drivin for awhile and I stop, it will misfire at idle then correctitself, run smooth, then miss again, and it will keep doing that until I take off again.
Old Feb 6, 2009 | 03:01 PM
New User
I finally found out what it was. It was the gap on my plugs. I regapped my plug and it stopped the misfire, i then regapped all the other ones and now the car feels like it has alot more power. Something simple as a plug gap made my car run like crap.
DanielCarswell
Dec 13, 2007 12:59 PM
iwantturbo
Mar 20, 2006 05:02 PM
antig24
Feb 5, 2006 12:16 PM
GaGen6v6
Aug 12, 2005 12:05 PM
