clutch problem??plz help!!!
Old Feb 6, 2009 | 12:04 PM
integragsssr's Avatar
Default clutch problem??plz help!!!
aww the problem is the clutch all of the sudden starts slipping nasty..than i just bleed it and it works fine for like 2 months or so and it does the same problem.everytime it does it i have to bleed it!...the clutch was changed like 6 months ago cause of thought it was the clutch but is not!..the car is a 99 gsr....help plz!!
Old Feb 6, 2009 | 12:06 PM
Default Re: clutch problem??plz help!!!
someone must know something pplz help!!
Old Feb 6, 2009 | 12:40 PM
someone?
Old Feb 6, 2009 | 01:34 PM
wunfstgsr's Avatar
Loved
Community Favorite
Try checking or replacing the clutch slave cylinder and clutch master cylinder not that expensive and this could fix the prob good luck.
Old Feb 6, 2009 | 01:38 PM
thanx for ur help
Old Feb 6, 2009 | 02:31 PM
Old Feb 6, 2009 | 02:47 PM
Jimmy's Avatar
Global Moderator
Where the clutch pedal is inside the car.. look all around and up in there and see if you see signs of leaking fluid.. the seal tends to go bad.. which causes this leaking.. be sure to double check good.
Only thing i can think of is happening is your loosing fluid.. which leads to air in the lines.. then you bleed and viola problem is fixed..
Do you ever haft to add fluid to the reservoir?
Old Feb 6, 2009 | 02:57 PM
no i never have to add fluid......this **** is wierd
Old Feb 6, 2009 | 02:59 PM
Jimmy's Avatar
Global Moderator
So the fluid level remains normal when this happens?
Old Feb 6, 2009 | 03:09 PM
yes ...the fluid is normal when it happens>i can find wat it is
Old Feb 6, 2009 | 03:47 PM
cmon more help plz
Old Feb 6, 2009 | 04:49 PM
1Point8DC2's Avatar
i would look into the slave cylinder maybe its hanging up and keeping the clutch partially depressed.
Old Feb 6, 2009 | 06:34 PM
ok ill check that...........mmm ohh and when it happens the clutch pedal isabit high
Old Feb 6, 2009 | 08:24 PM
any other advice???
Old Feb 6, 2009 | 08:54 PM
Jimmy's Avatar
Global Moderator
Originally Posted by integragsssr
any other advice???
I'm not sure what the issue is, but your topic is already on the top of the first page.. give it a little bit.. someone else might come across it and shed there input..
no need to repeatedly bump the thread.
Thanks & GL.
06typeSEX
12
Jun 1, 2009 02:12 PM
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
snyderman5
Dec 26, 2005 11:30 AM
stRtypR25
Jan 21, 2003 08:45 PM
91DA9
Feb 5, 2002 07:57 AM
