D16 dx starting problem, fires but dont go!!
well here is my issue. i start my car and sometimes it will start and it wont start. when it starts and warms up, i can shut it off and it will start right up like a normal car would.
when i first start my car it feals like its firing but it dont keep going. like you crank the motor then you feal it combust 1 time but it slows back down to starter speed and repeats. if i am lucky it starts.
any ideas? is it still the distributor?
drives fine when it runs. only reads the speed sensor code. and when i check the code the srs light blinks.
I'd start by checking the main relay, as well as the coil and ICM in the distributor.
loayo
11
Mar 12, 2012 12:49 PM
EFEvedell
11
Dec 1, 2011 09:47 AM
BolivianFuego
Nov 8, 2010 07:51 PM
Ak_ef9
Jun 12, 2009 11:42 PM
