intake-air-temperature sensor harness
Old Aug 8, 2002 | 01:23 PM
jseames's Avatar
Default intake-air-temperature sensor harness
Does anyone know where the intake-air-temperature (IAT) sensor harnes is on a 1990 crx?
[Modified by jseames, 10:25 PM 8/8/2002]
Old Aug 8, 2002 | 05:40 PM
vtecrx's Avatar
Default Re: intake-air-temperature sensor harness (jseames)
it is on the timing belt side of the manifold on the dx and si. just look for a white sensor srcewed into the intake manifold and you will find the harness
Andy
Old Aug 8, 2002 | 07:45 PM
flat-blk-HB's Avatar
Default Re: intake-air-temperature sensor harness (vtecrx)
If this sensor is messed up or in improer working order what will the ccar run like. I know it should throw a code (10) but will the car Idle super low? Sorry about using your post bro I was just wondering cause we just got done with a swap with a friends 89 HB B18A powered.hahahaha.
Old Aug 9, 2002 | 11:25 AM
jseames's Avatar
thanx. also have you heard of this IAT timing ticker that uses 4.7k ohm, 1/2 watt resistor, that when put into the sensor harness changes the fuel oxygen ratio to increase horsepower? If so does it do any damage because the harness is not supposed to be pluged back in. It just reads off of the resistor. When I tried it the check engine light came on and I don't know if it is safe for it to be like that.
justdoinme23
Jun 21, 2011 01:12 AM
Bboy_Trevstuh817
Oct 31, 2006 07:44 PM
CrazyHB
Aug 30, 2004 12:15 PM
bksracer01
Nov 25, 2003 08:51 PM
