D16z6 main bearing need help
i just got my block back from the machine shop he has told me that i need a red bearing on my number 3 main i had given him king standared bearings and he had measured them them and came up with this.....
main with customer supplied bearings
housing W/ bearing shaft clearance
1 2.1665 2.1645 .0020
2 2.1666 2.1644 .0022
3 2.1655 2.1648 .0007
4 2.1666 2.1646 .0020
5 2.1666 2.1647 .0019
rods with customer supplied bearings
1 1.7728 1.771 .0018
2 1.7728 1.771 .0018
3 1.7728 1.771 .0018
4 1.7728 1.7709 .0019
the clearance for the book says that for the main bearings
standard (new) NO. 1,5 journals:
.018-.036mm(.0007-.0014 in.)
NO. 2,3,4 journals:
.024-.0042mm(.0010-.0017in.)
service limit .05mm(.002in.)
the clearance for the rods are
standard (new).020-.038mm(.0008-.0015in.)
my Question is by his measurements i am almost off the honda specs on the book and could they be a little bit tighter? and would it be better to tighten them up? and what to do with the NO. 3 main? i know i need a smaller bearing but I called honda and they just tell me to go with the markings on the block, its not the same crank and they dont seem to get that.
This is a vitara build for turbo about 450 WHP is what im shooting for.
I AM LOOKING FOR A CLEARANCE OF ABOUT .0017 on mains
NO. 2,3,4 journals:
ditch the king bearings, and go honda so you can mix and match for propper clearance, you got your measurements which is good, if you go to laskeyracing.com they have a honda bearing chart with the thickness of them in there, with good info, they do my cranks and they are very good.
TurboKneeGrow
13
Feb 29, 2008 03:40 AM
tek_civic
Aug 9, 2003 06:12 PM
bearing, bearings, clearance, d16z6, info, king, limit, main, mains, replacement, service, specs, thicknesses, tightening, turbo
