Few questions on ls/vtec dowels
I am about to do a final assembly on my build and was wondering if the cylinder head is shaved and block is decked would the dowels need to be shaved down as well?
you just got both resurfaced so your ok on that, if you shaved it enough that the dowls would bottom out, you would have more issues then that, like valves to close to pistons, and timing belt unable to tension properly, you have no worrys, if your that concerned, you could clay the pitons and measure that way, good luck with the build.
