Power Handling
What is the power handle rating at for 06 type S for the motor and tranny.
and how hard can i push the K20 in the 06 type S with a SC before needing seriouse rebuidling
save your parents money and leave the car stock.
You could actually try searching to find the answer you're looking for.
check out clubrsx.com they have some good sections for forced induction. go there.
Very trueful and good advice. I hqve heard stock internls can handle a good amount of power and abuse thou. Somwhere around the 350 whp mark. Depends on ur setup thou. Def check out clubrsx.
well not exactly my parents money seeing how iam 23 and war veteran........ and p.s. i only had have evo and sti before this on on the 4G63 and EJ257 they both handle 500AWHP to 550awhp no problems i prove and tested on both with 550awhp on the subie. except tranny needed dog-box and a new clutch
Theres a guy here in Tampa making a little over 400hp on stock block.Its in a Eg hatch though so maby a lighter car makes the motor have less of a strain cause its lasted awhile.
k20z1rsx, if you want good info on your car go to clubrsx.com. you'll learn that k20's make very good gain with very little effort. visit the turbo threads at clubrsx, majority of them are making 400hp+ on stock block.
