back seat problem
Old Feb 5, 2009 | 01:46 PM
dc-2_mike's Avatar
Default back seat problem
not with my gf haha
but anyway i was wiring up my speakers so i ran it threw under the back seat and i couldnt even get the dam thing off and now it doesnt even go back in. like the left and right sides sticks up. what the trick to putting the seat back in????
Old Feb 5, 2009 | 01:49 PM
TunerN00b's Avatar
Default Re: back seat problem
Back seat base, or back seat back?
The seat back is only held in place with the pivot. One side goes in, than the other, than you stuff a plastic clip on the bar the seat pivots on to keep it in place.
The seat base is held in place with some clips at the front, and a single bolt at the back. Pull the whole thing, get the front clips in place, then set the back down and install bolt.
Old Feb 5, 2009 | 01:52 PM
dc-2_mike's Avatar
its the base like what you sit on
not what your backs against
thnx ill try that
Old Feb 5, 2009 | 03:22 PM
TunerN00b's Avatar
thnx ill try that
Remove the back. Fully remove the base. Get the front clips in place first, then set the back down. If it requires pressure to get the wire attached to the seat flat against the floor (the one the bolt goes through), the front tabs aren't lined up right, so remove and try again.
Took me 3 tries before I got the front in place correctly enough for the back to sit flat. Damn thieves popped the front clips out without removing the bolt lifting my rear seat looking for the fuel pump kill that wasn't there...
Old Feb 6, 2009 | 05:29 AM
berb_15's Avatar
Make sure your clips are lined up then apply a lot of pressure to get them in. I had to put a good amount of my body weight into popping them back into place.
Old Feb 6, 2009 | 06:11 AM
hatchling37's Avatar
The little J hooks are a little tricky, but once you get them to line up, it pretty much just slips into place.
Bob Ragan
Honda Ruckus and Scooters
Apr 15, 2018 05:06 PM
liam821
Jul 17, 2010 08:52 AM
michammond81
Dec 17, 2007 05:52 PM
hoang
May 22, 2005 09:09 AM
CivicExPimp
May 9, 2002 09:08 PM
