DA radiator
Its not going to bolt right up, you will probably have to do a custom mounting job. Is it just the single cam in the EF? if it is it will fit for sure but if its swapped or turbo you might run into some problems.
Why do you want to put a DA radiator in an EF? Most of the people I know with DA's want the half size radiator lol.
Assuming the header clearance isn't an issue, I think you would just need to move one or both of the bottom mounts and make a little bracket for the top.
i believe it is a direct fit, other than the larger inlet and outlet. i believe the stock hoses will fit, but will be extremely tight. i sold my spare DA radiator a week before i bought my crx, dammit.
It fits just fine, and I'm about 75% sure it will bolt right up. You will most likely want to pick up some new hoses though because the diameter of the stockers is too small.
