92 Accord lighting problem, please help!
I have a 92 Accord LX, 276K miles and going. I just had the whole timing belt thing done. Normally, I work on my car myself. But where I live now I don't have the tools or the space to do something this invasive. So I took it to a shop. When I got it back from them, I immediately had a new problem. I may take them to court over this, but if it's a simple fix I'll spare myself (and them) the drama. Here's the break down:
left = driver's side.
My Headlights don't turn on. The bulbs are fine, I even replaced them to be sure. All lights on the rear of the car work normally. Here are the various lighting abnormalities in various switch positions:
Off position:
-left turn signal works, right turn signal operates but parking light blinks instead (wtf ???).
Parking Light position:
-left turn signal works, right turn signal fails to operate at all.
-both parking lights work.
-right bumper light works, but left one fails to operate.
Headlight position:
-right side parking light fails to work, while the left is still operational.
-right bumper light fails to work, while the left magically comes to life (like they trade places).
-Headlights do not work.
-Brights work.
The first thing I checked for was a bad fuse. All fuses are fine. Then I checked the lighting relay under the hood, it clicks and has continuity. I checked all of the connections with the actual bulbs and each light is securely fastened to it's repsective harness (which I hoped would explain the parking light acting a turn signal, but apparently not). I took it back to the shop, actually immediately after I turned my lights on in their parking lot, and they deny responsibility. They, of course, would be happy to look at it for another fee even though I shelled out $1K for the timing belt work.
I'm baffled, could it be the switch on the steering column? Thanks...
Off position:
Headlight position:
-Brights work.
Off position:
Headlight position:
-Brights work.
Off position:
Headlight position:
-Brights work.
You overpaid for the tbelt job.
P
"You overpaid for the tbelt job."
no kidding! I was pissed. But no going back now.
I'll check for a loose ground, thanks for the tip!
Ah ha. FIXED IT.
It was a ground. Thanks for the tip off. The headlights & passenger turn signal share the same ground through a box that connects all of these ground wires to a single washer connection to the engine bay's wall.
Why the shop disconnected this, I'll never know. I just connected it to the wall via the air-box's bracket, and suddenly my lights are back in action.
HondaAccord333
Feb 19, 2018 08:04 AM
techsupport
Feb 13, 2017 08:09 AM
Nick Rankin
Sep 22, 2016 06:27 AM
