Vtec arm rocker failure
Old Feb 5, 2009 | 08:35 AM
kbs's Avatar
kbs
Default Vtec arm rocker failure
Hi
Yesterday we have pulled out the engine from our Drag racing Civic Ls-Vtec, the car ran fine for a year and a half only for the strip like one time by month, so now we decided to make some refresh.
PCT pistons, P&P head, Crane cams 11,6 lift in and 11,1 on exh, it made 205 whp.
The surprise is that the Vtec arm rockers gone wrong, we thought it was lubrication problems but every bearing, crank, etc were like new except this,
What thing could fail? we didn´t change the LMA, it has the old style hidraulic piston, could be that?
Any idea?
Thanks
Old Feb 5, 2009 | 09:44 AM
havok hybrid's Avatar
Default Re: Vtec arm rocker failure
I had a the same issue on my setup. I lost a OEM cam and the rockers.. Due to the springs being to strong. It happend two times thats when i knew it was not a oiling issue.
Check the top of the valve stem where the rocker pushes on it. If there is pits on it .. Your springs are too strong. Just my .02
Old Feb 5, 2009 | 09:56 AM
Furyof4's Avatar
This is becoming more and more common. I believe its because of the decrease in oil quality available of the shelf now and the fact that the newest rocker arms out of the showroom are now 8 years old.
What oil were you using?
Old Feb 6, 2009 | 07:21 AM
kbs's Avatar
kbs
I´m using GT1 10w/60 Liqui Moly with Ceratec
The spring are Crane made for these cams and the top of valves are fine :S.
Old Feb 6, 2009 | 09:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
holy CRAP man why such a thick oil?!?! I'm surprised that oil was even able to make it in between the bearing surfaces.
Old Feb 6, 2009 | 10:57 AM
kulo's Avatar
what is a good weight to use?
5w30?
Old Feb 8, 2009 | 10:13 AM
greasemonkee's Avatar
Modern oils with low ZDDP are the culprit, (in addition to the heavy springs.) During breakin you should use at the least a good diesel oil, but better yet an off road oil with high levels of ZDDP. GM EOS would help also, for break in only.
I run Rotella synthetic anymore after seeing the damage and how anemic zinc is in automotive oils
juan23_adolfo
Sep 3, 2017 06:30 PM
Teamdiesel
13
Jul 13, 2009 06:30 AM
turbo boost
May 7, 2009 11:22 AM
savitskiyivan
May 15, 2007 08:42 AM
l
Jan 2, 2002 12:54 PM
