Gauge Cluster Install Q?
Im installing an integra gauge cluster into my 6th gen civic and i am wondering how to pull the wires out of the civic plug to change them around for the integra cluster. Any help is greatley appreciated.
thanks
thanks
Hell no... don't cut and splice anything. You just pull the little white things out of the back of them then use a bobby pin or paper clip to pop the harness pins out and move them around to work with the Teg cluster.
Merrit has a good write up on how to do it at her site, merritr.com
You can see what my ITR cluster in my EK looks like at my site, t24ever.com
Good luck!
Good luck!
Good luck!
Good luck!
...exactley how i ended up doing it, but i have a problem, the engine temp gauge goes all the way to hot when i start the car and the turn signals seem to interfere with the speedometer and tachometer.
oh yeah try this faq. I am the one that helped the guy who wrote this faq and i think it should be a little more acurate.
http://www.fifthgearonline.com/installs/gsrcluster.htm
