is there a way to tell which lcas you have?
im going to buy some lcas and im unsure of which ones I need. car is a 93 del sol with disc brakes. i could have ls trailing arms is there a way to tell? thanks
it doesnt matter what trailing arms you have. there are two types of trailing arms. Integra type r trailing arms and the regular arms youmore than likely have on your car.
Does your trailing arm mount the shock on the inside of the arm or is the shock mounted on the outside. If it mounts on the inside than means you have jdm type r suspension which would more than likely also be 5 lug.
always buy LCA's for you car unless you have jdm type r suspension.
http://cgi.ebay.com/ebaymotors/Hardr...Q5fAccessories
interesting this is why i was asking ^^ so would it work on my 93 eg?
92-95 Civic (Require 94-01 Integra GSR / LS Rear LCA
this kit will also work with 92-95 Civic with the exception of rear lower control arm bushings.
if you use GSR/LS Rear lower control arms, this kit will work on your 92-95 Civic.
ShinotakuX
Jul 20, 2009 06:06 PM
