does an SiR hood REALLY provide more clearance?
Old Aug 8, 2002 | 11:00 AM
SuperCivic's Avatar
Default does an SiR hood REALLY provide more clearance?
with my new engine bolted in, hood clearance is now an issue is an SiR hood the answer?
Old Aug 8, 2002 | 11:08 AM
Freakn8's Avatar
Default Re: does an SiR hood REALLY provide more clearance? (SuperCivic)
there's a reason honda used it on the SiR
Old Aug 8, 2002 | 11:13 AM
guttedEF's Avatar
An SiR hood would give you the clearance you need for a B motor. But it will only fit on your car properly if you have the JDM EF SiR front end on your car. The JDM ZC hood will also give you the added clearance you need, and it will fit on the USDM front end. Check out http://www.JDMHondaparts.com, they sell both the SiR front end conversion, and they sell ZC hoods.
Old Aug 8, 2002 | 11:16 AM
SuperCivic's Avatar
Default Re: does an SiR hood REALLY provide more clearance? (guttedEF)
yes..i had a b16 in using hasport mounts..but the b20 is a little taller and is actually touching the hood when closed. i'm asking about SiR style CF hoods..looking for input from people who have them..thanks
Old Aug 8, 2002 | 11:27 AM
markedOO1's Avatar
when'd ya swap the b20 in?? I need to pay closer attention...
Old Aug 8, 2002 | 11:31 AM
Mugen Dom's Avatar
ask mugenef7 he can tell u having one
Old Aug 8, 2002 | 11:40 AM
brad.'s Avatar
Default Re: does an SiR hood REALLY provide more clearance? (jdmb18hatch)
yep...ask marty...that dude never goes on AIM!
Old Aug 8, 2002 | 12:08 PM
dumbchild's Avatar
just cut the ribs out of your stock hood.
Old Aug 8, 2002 | 12:14 PM
raene's Avatar
You have clearance issues? Which kit are you using? I had no problems, I'm surprised you did.
Old Aug 8, 2002 | 02:32 PM
FredoTheChimp's Avatar
Default Re: does an SiR hood REALLY provide more clearance? ([626]JDM-b16a-EF9)
who sells the SIR style hood....
Old Aug 8, 2002 | 05:53 PM
bryant's Avatar
Default Re: does an SiR hood REALLY provide more clearance? (Accord92sir)
visracing, fiberimages, 161822, just to name a few.
Old Aug 8, 2002 | 05:55 PM
bryant's Avatar
Default Re: does an SiR hood REALLY provide more clearance? (CR-X)
To bad they dont ship anymore, pickup only.
Old Aug 8, 2002 | 08:17 PM
marty's Avatar
I have fit all of the following motors in my car with the Fiber Images SiR style carbon fiber hood in my car with plenty of clearance.
B18C1
B18C-R
B16A
B18A/B16 head (LS/VTEC)
There is alot of clearance underneath the hood and it fits great. Heres a frontal pic of the Fiber Images Carbon Fiber Hood.
Old Aug 8, 2002 | 09:49 PM
xpsonic's Avatar
yes it does provide a lot more clearence....the metal stock jdm hood sure does dent easily though..
Old Aug 8, 2002 | 10:13 PM
JalopySiR's Avatar
How bad are you rubbing? Try the washers and longer bolts trick to raise the rear of the hood. Also good for underhood cooling Also, since you are still "swapping" you can shim down the engine with washers in the mounts...
Old Aug 8, 2002 | 10:35 PM
Lamchop0000's Avatar
i emailed 161822 they dont make them. there jdm style ones are made for the sir conversion. but they said they could get a sunnystyling one.
Old Aug 8, 2002 | 10:39 PM
Mugen Dom's Avatar
Default Re: does an SiR hood REALLY provide more clearance? (lamchop0000)
or u could goto inlinefour.com they have them for both sir and normal civics
Old Aug 9, 2002 | 07:00 AM
xci_ed6's Avatar
he he he, a/c VW style!
-Dustin
Old Aug 24, 2002 | 02:11 PM
SuperCivic's Avatar
Default Re: does an SiR hood REALLY provide more clearance? (Autocratic_1st_Gen)
fyi..i lowered the spring down a little bit and it works..no more rubbing ..although i'd still like a cf hood, it's impossible to find one for less than 500 shipped
Old Aug 24, 2002 | 03:10 PM
andrew dc's Avatar
buy my sir hood.. hahaha
Old Aug 24, 2002 | 08:46 PM
xtrafastcivic's Avatar
Default Re: does an SiR hood REALLY provide more clearance? (CRX25)
my engine fits fine i wish i can raise up the motor when i get my new hood
menappi
Aug 13, 2005 06:03 PM
speed_racer012
Mar 10, 2004 04:23 PM
CRexcellence
10
Nov 26, 2002 07:59 PM
mini-cRx
May 2, 2002 04:14 PM
