Help With Starting Problem
Old Feb 4, 2009 | 10:04 PM
paowa's Avatar
Default Help With Starting Problem
I have a 2000 civic si coupe. When i was coming home from school today, my car died at the stop light. When i try to start the engine, it makes a swish noise like a belt noise. I checked the cap and rotor which seems to be fine. I can't get it to start. Every time i turn on the ignition, it spins but i won't get any power for the engine won't start. Any heads up? can it be my timing belt?
Old Feb 4, 2009 | 10:14 PM
Lateralus_EG's Avatar
Default Re: Help With Starting Problem
broke timing belt?
Old Feb 4, 2009 | 10:23 PM
paowa's Avatar
i opened the valve cover and the belt seems to be good, not broken or anything
Old Feb 4, 2009 | 10:38 PM
Check to make sure ur getting fuel. I had sort of the same problem. My car was running fine then just up and died and wouldn't start again. Turned out to be a bad fuel pump. Even if u hear it prime doesnt it could still be bad. Mine was turning on just not pumping any fuel.
Baroc
Sep 21, 2012 07:50 AM
peAches yO
Apr 29, 2011 09:52 PM
idewson
Apr 21, 2006 08:39 PM
grnteg98
Jun 28, 2005 05:50 PM
94_CRVtec
Apr 23, 2005 10:26 AM
