Re-torque head question
Old Aug 8, 2002 | 11:00 AM
zerofighter777's Avatar
Default Re-torque head question
Would it be ok if i loosend my head bolts and re-torque them with having to replace the head gasket on my b16? thanks
Old Aug 8, 2002 | 12:08 PM
IlikeTODA's Avatar
Default Re: Re-torque head question (zerofighter777)
People do reuse head gaskets, I don't recommend it because my thinking is if somethings worth doing its worth doing correct. Why do you want to do this? Just curious.
Thanks, J
Old Aug 8, 2002 | 12:21 PM
kinesistech's Avatar
If you think they may be loose, just retorque them w/o loosening them. Some headgaskets require that you go back and retorque. I wouldnt recommend reuseing a headgasket. It might not hold.
Old Aug 8, 2002 | 12:58 PM
riceboy's Avatar
Default Re: Re-torque head question (kinesistech)
Old Aug 8, 2002 | 03:06 PM
Default Re: Re-torque head question (IlikeTODA)
Thanks, J
I have a small/minor oil-leak between the head and the block and alot of people told me just to re-torgue it. I just had a new oem head gasket put on. thanks for your replies
Old Aug 8, 2002 | 04:10 PM
tinkerbell's Avatar
did you re-use the head bolts?
they can stretch and may need to be re-torqued after they heat up a couple of times.
hth,
t..
PS is the leak near the VTEC solenoid?
Old Aug 8, 2002 | 04:25 PM
fixhondas's Avatar
New headgaskets should NOT leak.
Old Aug 9, 2002 | 03:39 AM
Default Re: Re-torque head question (tinkerbell)
hth,
t..
Yes the leak is near the vtec solenoid. Right where the head curves(corner).
Old Aug 9, 2002 | 06:28 AM
tk's Avatar
tk
Always use new head bolts exept when using ARP.
Always check the straightness of the block and head surfaces
Tom...www.tkmotion.com
14 NHRA Records...Porting...Flowbench
Making the fastest cars faster!
Old Aug 9, 2002 | 06:39 AM
Ri5e's Avatar
Default Re: Re-torque head question (tk)
It is OK to use an old headgasket only if its only been used for a little bit. I reused mine (2 months) old and it works fine.
Old Aug 9, 2002 | 09:05 PM
tinkerbell's Avatar
check/replace teh VTEC solenoid gasket before you stress about a leaking HG.
maybe it was taken off or has gone bad...
HTH,
t..
Old Aug 10, 2002 | 07:12 AM
earl's Avatar
ChRiS_p123
Apr 8, 2010 10:27 PM
Joker_God
12
Nov 30, 2009 01:34 PM
1POINT8L
Jul 22, 2008 07:19 PM
Day-DayC
May 18, 2006 08:51 PM
t-blizzard
Feb 15, 2003 01:56 AM
