Balance Shafts
Old Feb 4, 2009 | 08:02 PM
mayhemdestroy's Avatar
Default Balance Shafts
Is it possible to make high hp on a built h22 still having the 2 balance shafts in the block (not using b/s belt) and using a Endyn's modified oil pump? Or is it just better to eliminate them and use the modified oil pump?
Old Feb 5, 2009 | 04:28 AM
Default Re: Balance Shafts
bump hmmmm
Old Feb 5, 2009 | 09:31 AM
bumpo!! wow
Old Feb 5, 2009 | 09:48 AM
jlude90's Avatar
if you're going to have endyne modify the pump, why would you leave that shafts in if you aren't going to run them?
Old Feb 5, 2009 | 09:47 PM
InvaderTrax's Avatar
Could be a budget thing. The cost of the kit doesn't always offset the 8lbs you'll save
Old Feb 6, 2009 | 07:40 AM
jlude90's Avatar
he's already getting an endyne modified oil pump, i didn't get the feeling that he was sweating money
Old Feb 6, 2009 | 09:38 AM
i went ahead and ordered the Kaizenspeed Balance Shaft Removal kit. Just kinda wierd how i bought this allready built h22a4 motor and the b/s werent removed already.Hopefully i can do this install myself because no one around this town knows anything about this.
Old Feb 6, 2009 | 09:41 AM
Thanks for replying! Just needed to see if anyone has ever done this before with high hp.
Old Feb 6, 2009 | 08:37 PM
jlude90's Avatar
my advice is to get everything pressed in at the machine shop, unless you have a press, i tried to do that on my bench vice, and it didn't work out all too well
Old Feb 7, 2009 | 07:19 AM
Cool thanks dude!! Ill do that.
mayhemdestroy
Feb 5, 2009 04:30 AM
Varano44
Sep 5, 2008 10:26 PM
BlUAc
Aug 6, 2007 09:04 PM
95dcsleeper
Feb 13, 2007 07:54 PM
Lei Siew Long
Apr 17, 2002 08:54 PM
