Run wire from passenger door to engine bay?
Old Feb 4, 2009 | 06:52 PM
lmike6453's Avatar
Default Run wire from passenger door to engine bay?
Hey,
I'm trying to run a wire from passenger side by the ecu to the engine bay without going through the existing hole in the firewall.
Is there another way to run it or should I drill a new hole through the passenger side firewall?
Old Feb 4, 2009 | 10:26 PM
j_bizach's Avatar
Default Re: Run wire from passenger door to engine bay?
Why can you run it through an existing hole? That would be the easiest
Old Feb 4, 2009 | 11:27 PM
lmike6453's Avatar
The main reason why is to shorten the length of the cable...it is going from battery in hatch to fuse box/starter. The shorter I can make the cable, the less resistance.
Old Feb 5, 2009 | 04:45 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You could make another hole and use a grommet, but if you drill a hole under the dash with the dash still in the car, the hole will end up pretty low on the firewall. You could drill a hole right underneath where the under-hood fuse box sits, but I think you'd have to pull the dash to get to that area with a drill.
Old Feb 5, 2009 | 08:38 AM
lmike6453's Avatar
Damn, well thanks for the brainstorming. I will probably just end up using the pre existing hole vs the trouble of making another one.
TheOrangeHatch
Jun 23, 2015 11:09 AM
D-a-n_L
Honda Civic (2006 - 2015)
Sep 5, 2013 04:55 PM
Jack8788
Jul 9, 2006 07:40 AM
Basically
May 18, 2005 07:19 AM
jurenic
Mar 6, 2005 05:20 PM
