Best way to run power wire for battery relocation?
92 Hatch, no rear interior, no carpet. Only seats, dash, and door panels. Looking for a better way to run my power wire from the bay to the battery box in the back. Suggestions?
Re: Best way to run power wire for battery relocation?
On the exhaust tunnel side or door side? I was told there is also a channel that runs through the rocker, beneath the door jamb. Not sure if 0 gauge wire would run through that
I never narc'd on nobody!
On the door side. That's exactly where I had mine when I had an auxiliary battery in the trunk (along with something like 1200 watts of stereo hardware), and never had any problems. I tucked it under the factory plastics, but since you don't have those, a little bit of duct tape to keep it in place, and you should be golden.
Make absolutely sure you put a fuse near the battery, though. Having that long stretch of wire unfused is a recipe for disaster.
Sweet, I appreciate the info. Im going to tidy up the bay a bit more before my motor goes in so I'll probably reroute it when I take the dash out to finish removing the AC components
k on spray
03-12-2018 07:56 PM
niceprelude
12-24-2008 07:13 PM
Mashi2Choco
04-21-2008 11:29 AM
