wheel spacers
So i heard if you get the wheel spacers with the studs already on the spacer that you need to have the right off set on your rims so you your rim wont hit your stock studs my tire is 17x7 5x100/114.3 offset 42 will i be okay getting the h and r wheel spacer 15mm with the studs mounted to the spacer
RineRacing
12
Sep 27, 2003 09:57 AM
